I have been trying to add the Apache POI jar to my gateway using this method, but when I run a button with the following code under it:
import org.apache.poi.xssf.usermodel.XSSFWorkbook
I get the following error:
Traceback (most recent call last):
File “event:mousePressed”, line 1, in
ImportError: No module named poi
Ignition v7.9.6 (b2018012914)
Java: Oracle Corporation 1.8.0_161
I have both the packed and normal jar file under the common folder for the Ignition gateway. I also restarted the gateway multiple times but nothing has changed.
