Was able to reproduce the issue and will create an internal bug report since it does make sense that you should be able to access a specific element at a time.
Hello.
It look like the problem have been solved for normal Tag, but i am facing it with a Client Tag. I can not access a specific position of the array or bind to it. i can just get all of it at once.
It also don’t work with Dataset. i can’t by bind to an entry of the Dataset( is it even possible ?)
Can you please also have a look on it?
Thank you
It does appear that array client tags have the same tag binding issue. I’ve created another bug ticket to get this fixed (Bug-15002).
To bind to a dataset element, you can use an expression binding: {[Client]Dataset Tag}[row, col]
Until there’s a fix for array client tags, a similar expression binding can be used as a workaround by casting the tag value to a dataset first and then referencing it as such: toDataset({[Client]Array Tag})[row, 0]
