Ethernet/IP I/O Module
I’ve been testing with a 1734-AENT Point I/O assembly with four I/O modules: IE2C, OE2V, IB4, and OB4. You can use the configuration file I’ve constructed to run them as a template for your own setup:
<Controller>
  <DataTypes>
    <DataType Name="AB:1734_DI4:C:0" Handle="1124">
      <Member Name="Pt0FilterOffOn" DataType="INT" Dimension="0" />
      <Member Name="Pt0FilterOnOff" DataType="INT" Dimension="0" />
      <Member Name="Pt1FilterOffOn" DataType="INT" Dimension="0" />
      <Member Name="Pt1FilterOnOff" DataType="INT" Dimension="0" />
      <Member Name="Pt2FilterOffOn" DataType="INT" Dimension="0" />
      <Member Name="Pt2FilterOnOff" DataType="INT" Dimension="0" />
      <Member Name="Pt3FilterOffOn" DataType="INT" Dimension="0" />
      <Member Name="Pt3FilterOnOff" DataType="INT" Dimension="0" />
    </DataType>
    <DataType Name="AB:1734_DI8:I:0" Handle="2c1f">
      <Member Name="Fault" DataType="DINT" Dimension="0" />
      <Member Name="Data" DataType="SINT" Dimension="0" />
    </DataType>
    <DataType Name="AB:1734_DO4_NoDiag:C:0" Handle="2e4f">
      <Member Name="FaultMode" DataType="SINT" Dimension="0" />
      <Member Name="Pt0FaultMode" DataType="BIT" Target="FaultMode" BitNumber="0" />
      <Member Name="Pt1FaultMode" DataType="BIT" Target="FaultMode" BitNumber="1" />
      <Member Name="Pt2FaultMode" DataType="BIT" Target="FaultMode" BitNumber="2" />
      <Member Name="Pt3FaultMode" DataType="BIT" Target="FaultMode" BitNumber="3" />
      <Member Name="FaultValue" DataType="SINT" Dimension="0" />
      <Member Name="Pt0FaultValue" DataType="BIT" Target="FaultValue" BitNumber="0" />
      <Member Name="Pt1FaultValue" DataType="BIT" Target="FaultValue" BitNumber="1" />
      <Member Name="Pt2FaultValue" DataType="BIT" Target="FaultValue" BitNumber="2" />
      <Member Name="Pt3FaultValue" DataType="BIT" Target="FaultValue" BitNumber="3" />
      <Member Name="ProgMode" DataType="SINT" Dimension="0" />
      <Member Name="Pt0ProgMode" DataType="BIT" Target="ProgMode" BitNumber="0" />
      <Member Name="Pt1ProgMode" DataType="BIT" Target="ProgMode" BitNumber="1" />
      <Member Name="Pt2ProgMode" DataType="BIT" Target="ProgMode" BitNumber="2" />
      <Member Name="Pt3ProgMode" DataType="BIT" Target="ProgMode" BitNumber="3" />
      <Member Name="ProgValue" DataType="SINT" Dimension="0" />
      <Member Name="Pt0ProgValue" DataType="BIT" Target="ProgValue" BitNumber="0" />
      <Member Name="Pt1ProgValue" DataType="BIT" Target="ProgValue" BitNumber="1" />
      <Member Name="Pt2ProgValue" DataType="BIT" Target="ProgValue" BitNumber="2" />
      <Member Name="Pt3ProgValue" DataType="BIT" Target="ProgValue" BitNumber="3" />
      <Member Name="Pad" DataType="DINT" Dimension="0" />
    </DataType>
    <DataType Name="AB:1734_DO8:O:0" Handle="a272">
    </DataType>
    <DataType Name="AB:1734_DOB8:I:0" Handle="f497">
      <Member Name="Status" DataType="SINT" Dimension="0" />
    </DataType>
    <DataType Name="AB:1734_IE2:C:0" Handle="1cca">
      <Member Name="Ch0LowEngineering" DataType="INT" Dimension="0" />
      <Member Name="Ch0HighEngineering" DataType="INT" Dimension="0" />
      <Member Name="Ch0DigitalFilter" DataType="INT" Dimension="0" />
      <Member Name="Ch0LAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch0HAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch0LLAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch0HHAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch0RangeType" DataType="SINT" Dimension="0" />
      <Member Name="Ch0LimitAlarmLatch" DataType="SINT" Dimension="0" />
      <Member Name="Ch0AlarmDisable" DataType="SINT" Dimension="0" />
      <Member Name="Ch1LowEngineering" DataType="INT" Dimension="0" />
      <Member Name="Ch1HighEngineering" DataType="INT" Dimension="0" />
      <Member Name="Ch1DigitalFilter" DataType="INT" Dimension="0" />
      <Member Name="Ch1LAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch1HAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch1LLAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch1HHAlarmLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch1RangeType" DataType="SINT" Dimension="0" />
      <Member Name="Ch1LimitAlarmLatch" DataType="SINT" Dimension="0" />
      <Member Name="Ch1AlarmDisable" DataType="SINT" Dimension="0" />
      <Member Name="NotchFilter" DataType="SINT" Dimension="0" />
      <Member Name="RealTimeSample" DataType="INT" Dimension="0" />
    </DataType>
    <DataType Name="AB:1734_IE2:I:0" Handle="b81e">
      <Member Name="Ch0Data" DataType="INT" Dimension="0" />
      <Member Name="Ch1Data" DataType="INT" Dimension="0" />
      <Member Name="Ch0Status" DataType="SINT" Dimension="0" />
      <Member Name="Ch0Fault" DataType="BIT" Target="Ch0Status" BitNumber="0" />
      <Member Name="Ch0Calibration" DataType="BIT" Target="Ch0Status" BitNumber="1" />
      <Member Name="Ch0LAlarm" DataType="BIT" Target="Ch0Status" BitNumber="2" />
      <Member Name="Ch0HAlarm" DataType="BIT" Target="Ch0Status" BitNumber="3" />
      <Member Name="Ch0LLAlarm" DataType="BIT" Target="Ch0Status" BitNumber="4" />
      <Member Name="Ch0HHAlarm" DataType="BIT" Target="Ch0Status" BitNumber="5" />
      <Member Name="Ch0Underrange" DataType="BIT" Target="Ch0Status" BitNumber="6" />
      <Member Name="Ch0Overrange" DataType="BIT" Target="Ch0Status" BitNumber="7" />
      <Member Name="Ch1Status" DataType="SINT" Dimension="0" />
      <Member Name="Ch1Fault" DataType="BIT" Target="Ch1Status" BitNumber="0" />
      <Member Name="Ch1Calibration" DataType="BIT" Target="Ch1Status" BitNumber="1" />
      <Member Name="Ch1LAlarm" DataType="BIT" Target="Ch1Status" BitNumber="2" />
      <Member Name="Ch1HAlarm" DataType="BIT" Target="Ch1Status" BitNumber="3" />
      <Member Name="Ch1LLAlarm" DataType="BIT" Target="Ch1Status" BitNumber="4" />
      <Member Name="Ch1HHAlarm" DataType="BIT" Target="Ch1Status" BitNumber="5" />
      <Member Name="Ch1Underrange" DataType="BIT" Target="Ch1Status" BitNumber="6" />
      <Member Name="Ch1Overrange" DataType="BIT" Target="Ch1Status" BitNumber="7" />
    </DataType>
    <DataType Name="AB:1734_OE2:C:0" Handle="283b">
      <Member Name="Ch0FaultValue" DataType="INT" Dimension="0" />
      <Member Name="Ch0ProgValue" DataType="INT" Dimension="0" />
      <Member Name="Ch0LowLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch0HighLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch0FaultMode" DataType="SINT" Dimension="0" />
      <Member Name="Ch0ProgMode" DataType="SINT" Dimension="0" />
      <Member Name="Ch1FaultValue" DataType="INT" Dimension="0" />
      <Member Name="Ch1ProgValue" DataType="INT" Dimension="0" />
      <Member Name="Ch1LowLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch1HighLimit" DataType="INT" Dimension="0" />
      <Member Name="Ch1FaultMode" DataType="SINT" Dimension="0" />
      <Member Name="Ch1ProgMode" DataType="SINT" Dimension="0" />
    </DataType>
    <DataType Name="AB:1734_OE2:I:0" Handle="8d56">
    </DataType>
    <DataType Name="AB:1734_OE2:O:0" Handle="e19e">
    </DataType>
  </DataTypes>
  <Tags>
    <Tag Name="PointAI:C" DataType="AB:1734_IE2:C:0" Dimensions="0">
      <Data>
        00 00 10 27 00 00 00 80 ff 7f 00 80 ff 7f 03 00
        00 00 00 00 00 00 00 00 00 80 ff 7f 00 80 ff 7f
        03 00 00 06 00 00 00 00
      </Data>
    </Tag>
    <Tag Name="PointAI:I" DataType="AB:1734_IE2:I:0" Dimensions="0">
      <Data>
        00 00 00 00 a6 13 00 00 00 41 00 00
      </Data>
    </Tag>
    <Tag Name="PointAO:C" DataType="AB:1734_OE2:C:0" Dimensions="0">
      <Data>
        00 00 00 00 00 00 10 27 00 80 ff 7f 01 01 01 00
        00 00 00 00 00 00 00 00 10 27 00 80 ff 7f 01 01
        01 00 00 00
      </Data>
    </Tag>
    <Tag Name="PointAO:I" DataType="AB:1734_OE2:I:0" Dimensions="0">
      <Data>
      </Data>
    </Tag>
    <Tag Name="PointAO:O" DataType="AB:1734_OE2:O:0" Dimensions="0">
      <Data>
        00 00 ee 02
      </Data>
    </Tag>
    <Tag Name="PointDI:C" DataType="AB:1734_DI4:C:0" Dimensions="0">
      <Data>
        00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      </Data>
    </Tag>
    <Tag Name="PointDI:I" DataType="AB:1734_DI8:I:0" Dimensions="0">
      <Data>
        00 00 00 00 03 00 00 00
      </Data>
    </Tag>
    <Tag Name="PointDO:C" DataType="AB:1734_DO4_NoDiag:C:0" Dimensions="0">
      <Data>
      </Data>
    </Tag>
    <Tag Name="PointDO:I" DataType="AB:1734_DOB8:I:0" Dimensions="0">
      <Data>
      </Data>
    </Tag>
    <Tag Name="PointDO:O" DataType="AB:1734_DO8:O:0" Dimensions="0">
      <Data>
        0b 00 00 00
      </Data>
    </Tag>
  </Tags>
  <Assemblies>
  </Assemblies>
  <Modules>
    <Module Name="PointAI" CatalogNumber="1734-IE2C/C" Inhibited="false"
    Vendor="1" ProductType="115" ProductCode="24" Major="3" Minor="1"
    InRPI="250000" UnicastIn="true" InRTMF="0" OutRPI="250000" UnicastOut="true" OutRTMF="3">
      <EKey State="ExactMatch" />
      <Route>port 2 10.16.7.11 slot 1</Route>
      <Application>2004 247b 2cbe 2c65 800201000000</Application>
      <InputTag Size="10">PointAI:I</InputTag>
      <ConfigTag Size="38">PointAI:C</ConfigTag>
    </Module>
    <Module Name="PointAO" CatalogNumber="1734-OE2V/C" Inhibited="false"
    Vendor="1" ProductType="115" ProductCode="56" Major="3" Minor="1"
    InRPI="250000" UnicastIn="false" InRTMF="0" OutRPI="250000" UnicastOut="true" OutRTMF="4">
      <Route>port 2 10.16.7.11 slot 2</Route>
      <Application>2004 247b 2c66 2c65 800201000000</Application>
      <InputTag Size="6">PointAO:I</InputTag>
      <OutputTag>PointAO:O</OutputTag>
      <ConfigTag Size="36">PointAO:C</ConfigTag>
    </Module>
    <Module Name="PointDI" CatalogNumber="1734-IB4" Inhibited="false"
    Vendor="1" ProductType="7" ProductCode="130" Major="3" Minor="1"
    InRPI="100000" UnicastIn="false" InRTMF="0" OutRPI="100000" UnicastOut="true" OutRTMF="3">
      <Route>port 2 10.16.7.11 slot 3</Route>
      <Application>2004 2467 2cbe 2c03 800201000000</Application>
      <InputTag Size="5">PointDI:I</InputTag>
      <ConfigTag Size="20">PointDI:C</ConfigTag>
    </Module>
    <Module Name="PointDO" CatalogNumber="1734-OB4/C" Inhibited="false"
    Vendor="1" ProductType="7" ProductCode="231" Major="3" Minor="1"
    InRPI="100000" UnicastIn="false" InRTMF="0" OutRPI="100000" UnicastOut="true" OutRTMF="4">
      <Route>port 2 10.16.7.11 slot 4</Route>
      <Application>2004 247b 2c21 2c2b 800201000000</Application>
      <InputTag Size="5">PointDO:I</InputTag>
      <OutputTag Size="1">PointDO:O</OutputTag>
      <ConfigTag>PointDO:C</ConfigTag>
    </Module>
  </Modules>
</Controller>
