Failed to execute goal com.inductiveautomation.ignitionsdk
Ignition 7.9.3, Java Gateway and client -- 1.8.0_144-b01, Red Hat Linux
--- ignition-maven-plugin:1.0.12:post (post-module) @ hce-build ---
Installing /home/alam/ignitionsdk/ignition-sdk-examples/home-connect-example/hce-build/target/HomeConnectExample-unsigned.modl to gateway.
Deploying to http://localhost:8088/main/system/DeveloperModuleLoadingServlet
Reactor Summary:
home-connect-example .............................. SUCCESS [0.356s]
hce-gateway ....................................... SUCCESS [1.913s]
hce-build ......................................... FAILURE [0.583s]
BUILD FAILURE
Total time: 2.979s
Finished at: Fri Aug 11 00:19:05 GST 2017
Final Memory: 14M/162M
Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.12:post (post-module) on project hce-build: Could not post the module to the Gateway. Could not post module to gateway. http://localhost:8088/main/system/DeveloperModuleLoadingServlet -> [Help 1]
Tried this solution.. didn't work.
Java Additional Parameters
-Dia.developer.moduleupload=true
The -Dia.developer.moduleupload=true solution should work.
What does the additional parameters section of your ignition.conf look like?
wrapper.java.additional.1=-XX:PermSize=64m
wrapper.java.additional.2=-XX:MaxPermSize=128m
#wrapper.java.additional.3=-XX:+UseConcMarkSweepGC
#wrapper.java.additional.4=-XX:+CMSClassUnloadingEnabled
#wrapper.java.additional.5=-XX:+CMSPermGenSweepingEnabled
wrapper.java.additional.4=-Ddata.dir=/var/lib/ignition/data
wrapper.java.additional.5=-Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false
wrapper.java.additional.6=-XX:+UseG1GC
#wrapper.java.additional.8=-Dvision.urlproxy.enabled=true
#wrapper.java.additional.8=-Xdebug
#wrapper.java.additional.9=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
It should have “wrapper.additional.N” before it like all the other parameters, where N is whatever the next not-commented-out number would be.
works… awesome support :slight_smile:
