Hi All,
Thanks for the reply.
I am using a bit of code in PLC to go 1,0 every sec when the PLC is healthy.
Then I am using an expression tag with the following expression -
if(hasChanged({[.]PLC_Heartbeat}),1,0)
This tag is set as an alarm to flag up when the heartbeat is not healthy and I have set it to a 'clock' scan class.
I have tested it and this seems to be working fine with following errors -
- Any minor/major PLC faults.
- PLC network/comms error.
- Connecting/Disconnecting Device status in Ignition.
I guess its a round about way of getting it working. But seems to be giving me the result that I want. ![]()
Thank you all for help and direction.
