I am trying to connect osi pi database to Ignition database.
I have configer osi pi JDBC driver with dbVisualizer and can successfully see my tables and data.
And when I connect osi pi with Ignition the driver is connected correctly and shows installed and database connction says valid, however I can’t read data tables in the DB Browser and the error below is shown;
GatewayException: Unable to read response fron Gateway.
org.xml.sax.SAXParseException: The end-tag for element type “Response” must end with a ‘>’ deliminter.
