IP camera status - how to catch "Stream ended." status
Using script console I explored the PMIIPCamViewer object:
from com.inductiveautomation.factorypmi.application.components import PMIIPCamViewer
ip = PMIIPCamViewer()
dir(ip)
The hint about the parser attribute in the serialized fields documentation is misleading.
from com.inductiveautomation.factorypmi.application.components import FrameProducer
throws an exception:
ImportError: cannot import name FrameProducer
As Paul indicated there is no FrameProducer / parser attribute in the object.
>>> dir(ip)
['ABORT', 'ALLBITS', 'AccessibleJComponent', 'BOTTOM_ALIGNMENT', 'BaselineResizeBehavior', 'CENTER_ALIGNMENT', 'COMPONENT_RUNNING', 'ERROR', 'FRAMEBITS', 'HEIGHT', 'LEFT_ALIGNMENT', 'MODE_JPEG', 'MODE_MJPEG', 'PROPERTIES', 'RIGHT_ALIGNMENT', 'SOMEBITS', 'TOOL_TIP_TEXT_KEY', 'TOP_ALIGNMENT', 'UIClassID', 'UNDEFINED_CONDITION', 'WHEN_ANCESTOR_OF_FOCUSED_COMPONENT', 'WHEN_FOCUSED', 'WHEN_IN_FOCUSED_WINDOW', 'WIDTH', '__class__', '__copy__', '__deepcopy__', '__delattr__', '__doc__', '__eq__', '__getattribute__', '__hash__', '__init__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__unicode__', 'accessibleContext', 'action', 'actionMap', 'add', 'addAncestorListener', 'addComponentListener', 'addContainerListener', 'addFocusListener', 'addHierarchyBoundsListener', 'addHierarchyListener', 'addInputMethodListener', 'addKeyListener', 'addMouseListener', 'addMouseMotionListener', 'addMouseWheelListener', 'addNotify', 'addPropertyChangeListener', 'addVetoableChangeListener', 'alignmentX', 'alignmentY', 'ancestorAdded', 'ancestorListener', 'ancestorListeners', 'ancestorMoved', 'ancestorRemoved', 'ancestorResized', 'appContext', 'applyComponentOrientation', 'areFocusTraversalKeysSet', 'autoscrolls', 'background', 'backgroundSet', 'baselineResizeBehavior', 'border', 'bounds', 'cameraBufferSize', 'caretPositionChanged', 'checkImage', 'class', 'colorModel', 'componentAdded', 'componentCount', 'componentHidden', 'componentListener', 'componentListeners', 'componentMoved', 'componentOrientation', 'componentPopupMenu', 'componentRemoved', 'componentResized', 'componentShown', 'components', 'computeVisibleRect', 'connectRetries', 'containerListener', 'containerListeners', 'contains', 'countComponents', 'createImage', 'createToolTip', 'createVolatileImage', 'cursor', 'cursorCode', 'cursorSet', 'debugGraphicsOptions', 'deliverEvent', 'disable', 'dispatchEvent', 'displayable', 'doLayout', 'doubleBuffered', 'dropTarget', 'enable', 'enableInputMethods', 'enabled', 'equals', 'findComponentAt', 'firePropertyChange', 'focusCycleRoot', 'focusCycleRootAncestor', 'focusGained', 'focusListener', 'focusListeners', 'focusLost', 'focusOwner', 'focusTraversable', 'focusTraversalKeysEnabled', 'focusTraversalPolicy', 'focusTraversalPolicyProvider', 'focusTraversalPolicySet', 'focusable', 'font', 'fontSet', 'foreground', 'foregroundSet', 'getAccessibleContext', 'getActionForKeyStroke', 'getActionMap', 'getAlignmentX', 'getAlignmentY', 'getAncestorListeners', 'getAppContext', 'getAutoscrolls', 'getBackground', 'getBaseline', 'getBaselineResizeBehavior', 'getBorder', 'getBounds', 'getCameraBufferSize', 'getClass', 'getClientProperty', 'getColorModel', 'getComponent', 'getComponentAt', 'getComponentCount', 'getComponentListeners', 'getComponentOrientation', 'getComponentPopupMenu', 'getComponentZOrder', 'getComponents', 'getConditionForKeyStroke', 'getConnectRetries', 'getContainerListeners', 'getCursor', 'getCursorCode', 'getDebugGraphicsOptions', 'getDefaultLocale', 'getDropTarget', 'getFocusCycleRootAncestor', 'getFocusListeners', 'getFocusTraversalKeys', 'getFocusTraversalKeysEnabled', 'getFocusTraversalPolicy', 'getFont', 'getFontMetrics', 'getForeground', 'getGraphics', 'getGraphicsConfiguration', 'getHeight', 'getHierarchyBoundsListeners', 'getHierarchyListeners', 'getIgnoreRepaint', 'getInheritsPopupMenu', 'getInputContext', 'getInputMap', 'getInputMethodListeners', 'getInputMethodRequests', 'getInputVerifier', 'getInsets', 'getKeyListeners', 'getLayout', 'getListeners', 'getLocale', 'getLocation', 'getLocationOnScreen', 'getMaximumSize', 'getMinimumSize', 'getMode', 'getMouseListeners', 'getMouseMotionListeners', 'getMousePosition', 'getMouseWheelListeners', 'getName', 'getNextFocusableComponent', 'getParent', 'getPassword', 'getPeer', 'getPopupLocation', 'getPreferredSize', 'getPropertyChangeListeners', 'getRefreshRate', 'getRegisteredKeyStrokes', 'getRetryDelay', 'getRootPane', 'getScaleMode', 'getSize', 'getToolTipLocation', 'getToolTipText', 'getToolkit', 'getTopLevelAncestor', 'getTransferHandler', 'getTreeLock', 'getUIClassID', 'getUrl', 'getUserAgent', 'getUsername', 'getVerifyInputWhenFocusTarget', 'getVetoableChangeListeners', 'getVisibleRect', 'getWidth', 'getX', 'getY', 'gotFocus', 'grabFocus', 'graphics', 'graphicsConfiguration', 'handleEvent', 'hasFocus', 'hashCode', 'height', 'hide', 'hierarchyBoundsListener', 'hierarchyBoundsListeners', 'hierarchyChanged', 'hierarchyListener', 'hierarchyListeners', 'ignoreRepaint', 'imageUpdate', 'inheritsPopupMenu', 'inputContext', 'inputMap', 'inputMethodListener', 'inputMethodListeners', 'inputMethodRequests', 'inputMethodTextChanged', 'inputVerifier', 'insets', 'inside', 'invalidate', 'isAncestorOf', 'isBackgroundSet', 'isCursorSet', 'isDisplayable', 'isDoubleBuffered', 'isEnabled', 'isFocusCycleRoot', 'isFocusOwner', 'isFocusTraversable', 'isFocusTraversalPolicyProvider', 'isFocusTraversalPolicySet', 'isFocusable', 'isFontSet', 'isForegroundSet', 'isLightweight', 'isLightweightComponent', 'isManagingFocus', 'isMaximumSizeSet', 'isMinimumSizeSet', 'isOpaque', 'isOptimizedDrawingEnabled', 'isPaintingForPrint', 'isPaintingTile', 'isPreferredSizeSet', 'isRequestFocusEnabled', 'isScaleVideo', 'isShowStats', 'isShowing', 'isUseAuthentication', 'isValid', 'isValidateRoot', 'isVisible', 'keyDown', 'keyListener', 'keyListeners', 'keyPressed', 'keyReleased', 'keyTyped', 'keyUp', 'layout', 'lightweight', 'list', 'locale', 'locate', 'location', 'locationOnScreen', 'lostFocus', 'managingFocus', 'maximumSize', 'maximumSizeSet', 'minimumSize', 'minimumSizeSet', 'mode', 'mouseClicked', 'mouseDown', 'mouseDrag', 'mouseDragged', 'mouseEnter', 'mouseEntered', 'mouseExit', 'mouseExited', 'mouseListener', 'mouseListeners', 'mouseMotionListener', 'mouseMotionListeners', 'mouseMove', 'mouseMoved', 'mousePosition', 'mousePressed', 'mouseReleased', 'mouseUp', 'mouseWheelListener', 'mouseWheelListeners', 'mouseWheelMoved', 'move', 'name', 'nextFocus', 'nextFocusableComponent', 'nextFrame', 'notify', 'notifyAll', 'notifyStateChanged', 'opaque', 'optimizedDrawingEnabled', 'paint', 'paintAll', 'paintComponent', 'paintComponents', 'paintImmediately', 'paintingForPrint', 'paintingTile', 'parent', 'password', 'peer', 'postEvent', 'preferredSize', 'preferredSizeSet', 'prepareImage', 'print', 'printAll', 'printComponents', 'propertyChange', 'propertyChangeListener', 'propertyChangeListeners', 'putClientProperty', 'reconnect', 'refreshRate', 'registerKeyboardAction', 'registeredKeyStrokes', 'remove', 'removeAll', 'removeAncestorListener', 'removeComponentListener', 'removeContainerListener', 'removeFocusListener', 'removeHierarchyBoundsListener', 'removeHierarchyListener', 'removeInputMethodListener', 'removeKeyListener', 'removeMouseListener', 'removeMouseMotionListener', 'removeMouseWheelListener', 'removeNotify', 'removePropertyChangeListener', 'removeVetoableChangeListener', 'repaint', 'requestDefaultFocus', 'requestFocus', 'requestFocusEnabled', 'requestFocusInWindow', 'resetKeyboardActions', 'reshape', 'resize', 'retryDelay', 'revalidate', 'rootPane', 'scaleMode', 'scaleVideo', 'scrollRectToVisible', 'setActionMap', 'setAlignmentX', 'setAlignmentY', 'setAutoscrolls', 'setBackground', 'setBorder', 'setBounds', 'setCameraBufferSize', 'setComponentOrientation', 'setComponentPopupMenu', 'setComponentZOrder', 'setConnectRetries', 'setCursor', 'setCursorCode', 'setDebugGraphicsOptions', 'setDefaultLocale', 'setDoubleBuffered', 'setDropTarget', 'setEnabled', 'setFocusCycleRoot', 'setFocusTraversalKeys', 'setFocusTraversalKeysEnabled', 'setFocusTraversalPolicy', 'setFocusTraversalPolicyProvider', 'setFocusable', 'setFont', 'setForeground', 'setIgnoreRepaint', 'setInheritsPopupMenu', 'setInputMap', 'setInputVerifier', 'setLayout', 'setLocale', 'setLocation', 'setMaximumSize', 'setMinimumSize', 'setMode', 'setName', 'setNextFocusableComponent', 'setOpaque', 'setPassword', 'setPreferredSize', 'setRefreshRate', 'setRequestFocusEnabled', 'setRetryDelay', 'setScaleMode', 'setScaleVideo', 'setShowStats', 'setSize', 'setToolTipText', 'setTransferHandler', 'setUrl', 'setUseAuthentication', 'setUserAgent', 'setUsername', 'setVerifyInputWhenFocusTarget', 'setVisible', 'show', 'showStats', 'showing', 'shutdownComponent', 'size', 'startupComponent', 'toString', 'toolTipText', 'toolkit', 'topLevelAncestor', 'transferFocus', 'transferFocusBackward', 'transferFocusDownCycle', 'transferFocusUpCycle', 'transferHandler', 'treeLock', 'unregisterKeyboardAction', 'update', 'updateUI', 'url', 'useAuthentication', 'userAgent', 'username', 'valid', 'validate', 'validateRoot', 'verifyInputWhenFocusTarget', 'vetoableChange', 'vetoableChangeListener', 'vetoableChangeListeners', 'visible', 'visibleRect', 'wait', 'width', 'x', 'y']
I am testing a bandage polled idea using runScript() on a bindable property (eg. visible) with a custom method:
def setTrue(self)
	try:
		self.nextFrame()
#		system.gui.messageBox("success","nextFrame")
	except:
		self.reconnect()
		system.gui.messageBox("failure","reconnect")
	return True
Rationale is to periodically issue the PMIIPCamViewer object's nextFrame() method and -- if it fails -- try the reconnect() method.
For what it is worth, this is not a new issue, just unsolved:
  1. 2014: IP Camera Viewer - IOException: Premature EOF
  2. 2014: IP Camera not automatically reconnecting
  3. 2015: Refresh IP Camera Module on Error
  4. 2015: IP Camera Viewer Error & Recovery Question
