Mass creation of Tags and Alarms in xml
I found this technique very interesting for converting large amount of Tags and Alarms into Ignition compatible xml file. I found this idea in youtube just few hours back and still experimenting. I thought, i will post it here immediately so that you can also try and share your experience. Cheers :slight_smile:
  1. First, we have to create an XML schema xsd file. Schema is our template.
  2. In Ignition, basically we can create UDTs and 5 different types of tags.
  3. Create some sample tags (or UDTs) under each type, export as xml and save it as .xsd schema file . Let's say, we have 6 sample schemas.
  4. Classify your csv list of tags and alarms which needs to be converted as xml, into 6 types as per your 6 schemas. Save it into 6 Excel sheets.
  5. Now, you have to just map your Tags and Alarms in Excel sheets with the respective schema.
  6. Watch these videos and dig deeper.
Convert Excel Spreadsheet data to XML
Converting XLS to XML
Converting data from Excel to XML Template
Import & export XML data, XML maps and schema in exce
