Open a View without the shared dock
You’re mixing terminology. VIEWS do not have shared docks - only PAGES do. so if you want to open a View then you just need to use system.perspective.navigate(view='<view_path>'). If you want to open a PAGE without the shared Docked View you need to override the shared setting.
Overriding a shared Docked View:
You should see a configuration which looks like this, with the shared DOcked View greyed-out:
Screen Shot 2020-12-28 at 8.27.40AM
You should click the “+ Add” button, and configure a Docked View which uses the same view as the shared Docked View, but you should set the Display setting to “onDemand”, and set the Handle property to “hide”.
Screen Shot 2020-12-28 at 8.30.29AM
I think I’ve seen you post other threads in relation to this same issue, and I really think that your best option is going to be to have Vision-specific urls for these pages which have this configuration.
