Downloaded and installed the beta version as of 2019-01-08 08:00, and perspective is missing from the designer.
The following is in the designer console log
08:56:32.094 [AWT-EventQueue-0] ERROR designer.main - Failed to start Perspective module - unable to initialize browser
java.lang.NoClassDefFoundError: com/teamdev/jxbrowser/chromium/BrowserPreferences
at com.inductiveautomation.ignition.designer.JXBrowserUtil.startup(JXBrowserUtil.java:29)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadModules(IgnitionDesigner.java:753)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startup(IgnitionDesigner.java:453)
at com.inductiveautomation.ignition.designer.DesignerStartupHook$2.run(DesignerStartupHook.java:313)
Caused by: java.lang.ClassNotFoundException: com.teamdev.jxbrowser.chromium.BrowserPreferences
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
... 17 common frames omitted
I also have this issue. The wrapper.log shows the following error:
org.xml.sax.SAXException: XML Parsing of optional library manifest 'file.xml' failed due missing file 'jxbrowser-6.22.jar.jar'
Caused by: java.io.FileNotFoundException: lib/opt/jxbrowser/jxbrowser-6.22.jar.jar (No such file or directory)
/usr/local/bin/ignition/lib/opt/jxbrowser/jxbrowser-6.22.jar exists, but /usr/local/bin/ignition/lib/opt/jxbrowser/jxbrowser-6.22.jar.jar does not.
I tried adding a symlink for the .jar.jar as a workaround, but that doesn’t seem to change anything.
10:08:45.944 [AWT-EventQueue-0] ERROR designer.main - Failed to start Perspective module - unable to initialize browser
… 17 common frames omitted
Doesn’t look like last night’s publication included the fix, but it should be fixed in tomorrow’s build, so if your build is from 11Jan2018 or later and you continue to see issues with jxbrowser loading, please let us know.
I have the most recent version and am running on mac. I don't have the perspective tab in my project browser. I can't find anything in the forum recently regarding the issue. This was the closest I found but since it was so old I don't feel like it is relevant to the issue I'm having.
That’s one thing I was afraid of. It is 10.13.6. It’s an old computer but I couldn’t get it on my newer computer I think because of the VPN. It would install but never accept the license. Sounds like I will have to figure something else out then.
