Power Table configureEditor inside Template Repeater
Figured it out finally. Not sure if another setting in my Power Table is causing an issue when used in a Template repeater, but this worked for me. In case anyone else has the same issue:
Doesn't work on a power table in a template repeater
#configureEditor
        target = system.tag.read('[Client]Config/select_agitation').value
	ds = system.dataset.toPyDataSet(target)
	options = [(row["idSelect"], row["select_text"]) for row in ds]
	if colName == "Type":
		return {"options":options}
Works on a power table in a template repeater
		root = self
		from javax.swing import JComboBox, DefaultCellEditor, DefaultComboBoxModel
		class CustomCellEditor(DefaultCellEditor):
			def getTableCellEditorComponent(self, table, value, isSelected, row, column):
				comp = DefaultCellEditor.getTableCellEditorComponent(self, table, value, isSelected, row, column)
				data = []
				# get the available options for agitation type column from client tag.
				pyData = system.dataset.toPyDataSet(target)
				for row in pyData:
					# append second column (select_text)
					data.append(row[1])
				comp.setModel(DefaultComboBoxModel(data))
				return comp
		return {'editor': CustomCellEditor(JComboBox())}
