Hi,
Need help on how to manage SDL file.
It seems that the S14F1, S14F2 cannot be found in SDL.
I need help on how to add stream function in sdl.
Please see the following example:
"<Trans Name="S14F1" Desc="Strip Map" ReplyExpected="YES">
<Primary Stream="14" Func="1" Name="GAR" Desc="GetAttr request">
<Root>
<Item Name="L" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="OBJSPEC" Desc="Specific object instance" Format="A" IsArray="NO" Value="" />
<Item Name="OBJTYPE" Desc="Identifier for group or class of objects" Format="A" IsArray="NO" Value="StripMap" />
<Item Name="Li" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="OBJID" Desc="Identifier for an object" Format="A" IsArray="NO" Value="1002948021" />
</Item>
<Item Name="Lq" Desc="" Format="L" IsArray="NO" Value="" />
<Item Name="La" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="ATTRID" Desc="Identifier for an attribute for a specific type of object" Format="A" IsArray="NO" Value="LotID" />
<Item Name="ATTRID" Desc="Identifier for an attribute for a specific type of object" Format="A" IsArray="NO" Value="OriginLocation" />
<Item Name="ATTRID" Desc="Identifier for an attribute for a specific type of object" Format="A" IsArray="NO" Value="Rows" />
<Item Name="ATTRID" Desc="Identifier for an attribute for a specific type of object" Format="A" IsArray="NO" Value="Columns" />
<Item Name="ATTRID" Desc="Identifier for an attribute for a specific type of object" Format="A" IsArray="NO" Value="CellStatus" />
</Item>
</Item>
</Root>
</Primary>
<Secondary Stream="14" Func="2" Name="GAD" Desc="GetAttr data">
<Root>
<Item Name="L2a" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="Ln" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="L2b" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="OBJID" Desc="Identifier for an object" Format="A" IsArray="NO" Value="6117386410037" />
<Item Name="L2c" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="" Desc="" Format="L" IsArray="NO" Value="">
<Item Name="" Desc="" Format="A" IsArray="NO" Value="ORIGINLOCATION" />
<Item Name="" Desc="" Format="U1" IsArray="NO" Value="3" />
</Item>
<Item Name="" Desc="" Format="A" IsArray="NO" Value="ROWS" />
<Item Name="" Desc="" Format="U4" IsArray="NO" Value="9" />
</Item>
<Item Name="" Desc="" Format="A" IsArray="NO" Value="COLUMNS" />
<Item Name="" Desc="" Format="U4" IsArray="NO" Value="37" />
</Item>
<Item Name="" Desc="" Format="A" IsArray="NO" Value="CELLSTATUS" />
<Item Name="" Desc="" Format="A" IsArray="NO" Value="0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0" />
</Item>
<Item Name="" Desc="" Format="A" IsArray="NO" Value="DEFECTCODE" />
<Item Name="" Desc="" Format="A" IsArray="NO" Value="CANNOT BE BLANK OR SPACE. MUST CONTAIN SOMETHING." />
</Item>
</Item>
</Item>
</Item>
<Item Name="OBJACK" Desc="Identifier for an object" Format="U1" IsArray="NO" Value="0" />
<Item Name="L2c" Desc="" Format="L" IsArray="NO" Value="" />
</Item>
</Item>
</Item>
</Root>
</Secondary>
</Trans>"
