UDT to power table
Hi again.
Although this works, I’d like to further refine the functionality.
Using Jordan’s code from above I now have a dataset of tag paths.
  1. How can I use these tag paths to populate a power table so I don’t need to keep running the script to refresh my data?
  2. How do I trigger the script to run when a template is loaded? I’ve looked at several forum posts such as Template load event? but when I add this to PropertyChange, ignition throws an error upon saving.
