# 7.9.10 Upgrade - Scale Issues
**URL:** <https://forum.inductiveautomation.com/t/7-9-10-upgrade-scale-issues/21245>\
**Created:** [December 5, 2018, 8:33pm UTC](https://forum.inductiveautomation.com/t/7-9-10-upgrade-scale-issues/21245 "2018-12-05T20:33:15Z")\
**Showing post:** 15
**Author:** ![jcoffman](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/jcoffman/32/6429_2.png) [@jcoffman](https://forum.inductiveautomation.com/u/jcoffman)\
**Post date:** [December 10, 2018, 7:39pm UTC](https://forum.inductiveautomation.com/t/7-9-10-upgrade-scale-issues/21245/15 "2018-12-10T19:39:43Z")
Hi @weertske,
I was hoping you could provide me with some more info and maybe a screenshot? Here is what would be helpful:
1. Which version of windows you are running on.
2. Your DPI scaling. This is under your Display settings, specifically “scaling”. It would be useful to know the scaling for each monitor
3. a screenshot of your designer open with the scaling issues present that you are seeing.
As a workaround, could you try something for me and let me know if it works for you:
1. Could you use the new Client Launcher and create a desktop shortcut (or use one that you previously created from the new Client Launcher)
2. right click the shortcut and select properties.
3. append `-Dsun.java2d.uiScale=1.0` to the “target” field.
4. Launch the designer or vision client.
This argument will override the internal scaling and set it to some percent in floating point format. you can change the value “1.0” (which means 100%) to any other value to meet your needs. for example, change it to 2.0 which will scale the program to 200%.
I hope that helps and i look forward to hearing back from you.
Thanks,
Jonathan C.
_[View the full topic](https://forum.inductiveautomation.com/t/7-9-10-upgrade-scale-issues/21245)._
