# Add checkbox column in Ignition Perspective to filter other column
**URL:** <https://forum.inductiveautomation.com/t/add-checkbox-column-in-ignition-perspective-to-filter-other-column/89621>\
**Tags:** perspective\
**Created:** [April 29, 2024, 10:10am UTC](https://forum.inductiveautomation.com/t/add-checkbox-column-in-ignition-perspective-to-filter-other-column/89621 "2024-04-29T10:10:45Z")\
**Showing post:** 17
**Post date:** [April 29, 2024, 12:01pm UTC](https://forum.inductiveautomation.com/t/add-checkbox-column-in-ignition-perspective-to-filter-other-column/89621/17 "2024-04-29T12:01:51Z")
See also:
> [@Editing Perspective table with allowEditOn single-click still takes two clicks](https://forum.inductiveautomation.com/t/editing-perspective-table-with-allowediton-single-click-still-takes-two-clicks/30446):
> I have a table with two columns that are editable, a boolean and a string. I set the onCellEdit field to “single-click” however the real functionality seems to be click once to select the row, then click again to check the boolean or start writing to the text column. Is there a way to make it truly be like a work on a single click? I tried to use the onFocus and onRowclick but nether tell me what column was clicked, which would be enough for me to then programatically just select the box. An…
_[View the full topic](https://forum.inductiveautomation.com/t/add-checkbox-column-in-ignition-perspective-to-filter-other-column/89621)._
