# Adding Dropdown box into PowerTable
**URL:** <https://forum.inductiveautomation.com/t/adding-dropdown-box-into-powertable/11188>\
**Created:** [February 10, 2016, 2:50pm UTC](https://forum.inductiveautomation.com/t/adding-dropdown-box-into-powertable/11188 "2016-02-10T14:50:17Z")\
**Showing post:** 12
**Post date:** [October 6, 2021, 5:30pm UTC](https://forum.inductiveautomation.com/t/adding-dropdown-box-into-powertable/11188/12 "2021-10-06T17:30:05Z")
If you need dynamic flexibility, take a look at this post:
> [@Force configure cell update in power table](https://forum.inductiveautomation.com/t/force-configure-cell-update-in-power-table/16318/7):
> The much more efficient solution is to embed a custom editor, which will lookup the datasets dynamically whenever it’s appropriate. I’ve got a very simple example of this below; the project has an editable ‘Options’ dataset, and the available options in column B in the editable table will be dynamic based on the value in column A. The relevant code is here: root = self from javax.swing import JComboBox, DefaultCellEditor, DefaultComboBoxModel class CustomCellEditor(DefaultCellEditor):…
_[View the full topic](https://forum.inductiveautomation.com/t/adding-dropdown-box-into-powertable/11188)._
