Couldn't find anything related to my case so here it goes.
I have a schneider PLC that is connected to ignition through OPCUA.
I added tags from the PLC through OPC Browser. A simple OPC tag imports, no problem.
When I try to import a tag with a DDT structure in the PLC (which has a corresponding UDT definition in designer), it won't import the tag as a whole structure. It shows up as a normal OPC tag.
My workaround is to edit a json file and import all the tags that way.
Scratching my head here and thinking if I am just missing something here as importing through the OPC browser would have been really easy.
If you're expecting to drag a tag and it automatically link up to the Ignition UDT, I don't believe that's possible. The correct way to do this is to make a parameterized UDT that you can set the parameters on to get the tag to automatically link up to the tags in your PLC.
