# Any way to control tooltip on Chart
**URL:** <https://forum.inductiveautomation.com/t/any-way-to-control-tooltip-on-chart/1184>\
**Category:** Archived Topics\
**Created:** [June 16, 2009, 6:05pm UTC](https://forum.inductiveautomation.com/t/any-way-to-control-tooltip-on-chart/1184 "2009-06-16T18:05:55Z")\
**Posts on this page:** 4\
**Author:** ![Ron](https://avatars.discourse-cdn.com/v4/letter/r/ecae2f/32.png) [@Ron](https://forum.inductiveautomation.com/u/Ron)\
**Post date:** [June 16, 2009, 6:05pm UTC](https://forum.inductiveautomation.com/t/any-way-to-control-tooltip-on-chart/1184/1 "2009-06-16T18:05:55Z")
I have a chart that shows three different datasets. It is an XY Plot type. They all share the same X-axis, which is a number of hours a process has run. The datasets all have two columns, the first is the x value and is an integer. Everything displays fine on the chart. My issue is that when I hover over a point and PMI displays the tooltip, it shows the x-category as a fixed date. For example if I click on the gravity line, I get the following in the tooltip: Gravity: (12/31/69 4:00 PM, 3.9)
The Y-axis looks to be about 3.9, so I believe that is correct. Any idea why it is displaying the X-axis as a date? It does not appear to change from this date, even if I pick a value further along the x-axis.
**Author:** ![Carl.Gould](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/carl.gould/32/7262_2.png) [@Carl.Gould](https://forum.inductiveautomation.com/u/Carl.Gould)\
**Post date:** [June 16, 2009, 8:39pm UTC](https://forum.inductiveautomation.com/t/any-way-to-control-tooltip-on-chart/1184/2 "2009-06-16T20:39:09Z")
Unfortunately, no, currently the classic chart assumes you’ve got a timeseries x-axis, which is clearly a bad assumption.
I took the liberty of moving this to the feature request forum, it is something that we can fix.
**Post date:** [June 16, 2009, 8:43pm UTC](https://forum.inductiveautomation.com/t/any-way-to-control-tooltip-on-chart/1184/3 "2009-06-16T20:43:17Z")
Thank you Carl. We appreciate all the upgrades you guys have made to your application. They really do make creating a customized application a possibility for us.
**Post date:** [August 7, 2009, 10:26pm UTC](https://forum.inductiveautomation.com/t/any-way-to-control-tooltip-on-chart/1184/4 "2009-08-07T22:26:00Z")
This is in for 3.3.3 due out early next week.
