Audit log full from system.tag.writeBlocking calls
I upgraded Ignition from 8.1.17 to 8.1.18 on Monday (6/20). Version 8.1.17 did not log the system.tag.writeBlocking script calls in the audit log. Version 8.1.18 is logging all of them!
For example: I have a gateway timer script running to update a couple tags using the system.tag.writeBlocking function. I write the number of active and unacknowledged alarms to these tags so I can display an icon if there are alarms that need attention. Now when I get an alarm, the tag write function constantly gets recorded in the audit trail. This is occurring throughout my project in additional scripts. Any time a user pushes a button (perspective) that has a script to write to a tag not only does the user interaction get logged but also the tag write gets logged (sometimes it’s more than one tag write in the script).
I saw @nminchin 's post, requesting a way to disable. I don’t understand why this feature was added.
But this logging wasn’t happening in 8.1.17
My audit log is FULL of “tag writes”
BTW, I’ve cleaned up the timer script so it doesn’t write duplicate data but it’s still really annoying having a bunch of random “Unknown Actor’s” filling up the audit logs with ‘tag write’ entries.
Also, I did clear the Gateway Audit Profile but the tag writes are still getting logged.
I’m a bit confused how you would want this to work? For the majority of cases, I and most people want the audit log to capture all sources of tag writes into the audit log. Otherwise the audit log is kind of pointless, right?
The only reason that I want to skip logging is so that I can write my own logging code to log the previous value.
The system didn’t previously log perspective script tag writes so I had to build the project with custom audit logging. Now with this update I basically get double audit logging.
And, from my perspective (no pun intended) not all tag writes need to be logged. I have some memory tags that are used to just do a simple calculation (or count the number alarms). If these tags get changed it doesn’t affect my process.
Unfortunately, I don’t have the ability (time) to update all of the scripts to take advantage of the updated update.
I found the culprit
So I presume you have multiple scripts that all individually insert audit log entries after each tag write? You don’t have a single library function that does this?
I simply created two library functions shared.tag.writeBlocking and shared.tag.writeAsync which were wrapper functions to the same system functions. So to disable my own audit logging all I did was comment out the audit log insert statements in the two functions
I like the way you approached it, in hindsight I wish I would have done the same. I do have a main script that writes to the audit log, for the majority of the tag writes, but my script stores custom data (like batch information and equipment IDs) that the system audit log doesn’t capture. I use the information for batch reporting. So now in one button press I get my custom audit log and at least on system tag write log (and some cases 2 or 3 extra tag write logs).
I guess I can live with it but it was a surprise to see so much data stored in the logs today. It took me a while to even find what I was looking for. I get the concept but it’s a surprising change for an existing project.
