# Auto-Export all Vision window Documentation
**URL:** <https://forum.inductiveautomation.com/t/auto-export-all-vision-window-documentation/72643>\
**Tags:** ignition81, vision\
**Created:** [April 19, 2023, 1:33pm UTC](https://forum.inductiveautomation.com/t/auto-export-all-vision-window-documentation/72643 "2023-04-19T13:33:18Z")\
**Post date:** [April 19, 2023, 4:15pm UTC](https://forum.inductiveautomation.com/t/auto-export-all-vision-window-documentation/72643/2 "2023-04-19T16:15:07Z")
With [Ignition Extensions](https://forum.inductiveautomation.com/t/ignition-extensions-convenience-utilities-for-advanced-users/64615) installed, you could call `system.project.getProject()` to get an instance of the [`Project`](https://files.inductiveautomation.com/sdk/javadoc/ignition81/8.1.26/com/inductiveautomation/ignition/common/project/Project.html) Java class. From there, call `getResourcesOfType` with a resource type of `com.inductiveautomation.factorypmi.common.VisionModule.WINDOW_RESOURCE` (this'll only work directly in the designer; doing it from the gateway scope will be a bit trickier).
That will give you a list of `ProjectResource`s, which have a [`getDocumentation`](https://files.inductiveautomation.com/sdk/javadoc/ignition81/8.1.26/com/inductiveautomation/ignition/common/project/resource/ProjectResource.html#getDocumentation()) method.
Technically, Ignition Extensions is not required (you can access the project through other scripting means) but it's the easiest entrypoint.
_[View the full topic](https://forum.inductiveautomation.com/t/auto-export-all-vision-window-documentation/72643)._
