# Bad("Bad\_NotWritable: The access level does not allow writing to the Node.")
**URL:** <https://forum.inductiveautomation.com/t/bad-bad-notwritable-the-access-level-does-not-allow-writing-to-the-node/53813>\
**Created:** [December 6, 2021, 8:21pm UTC](https://forum.inductiveautomation.com/t/bad-bad-notwritable-the-access-level-does-not-allow-writing-to-the-node/53813 "2021-12-06T20:21:12Z")\
**Showing post:** 3
**Author:** ![bschroeder](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/bschroeder/32/13260_2.png) [@bschroeder](https://forum.inductiveautomation.com/u/bschroeder)\
**Post date:** [December 6, 2021, 9:53pm UTC](https://forum.inductiveautomation.com/t/bad-bad-notwritable-the-access-level-does-not-allow-writing-to-the-node/53813/3 "2021-12-06T21:53:54Z")
FWIW @Kevin.Herron I’ve been seeing this specifically on 8.1.11 if I’m doing a fairly large logic change and a Logix PLC (not SLC) and then try and write to a tag while the logic changes are currently being accepted. It usually clears up a couple of seconds after the logic has been accepted into the PLC. Same error message.
_[View the full topic](https://forum.inductiveautomation.com/t/bad-bad-notwritable-the-access-level-does-not-allow-writing-to-the-node/53813)._
