# Best Way to Return Data from Vision Popup
**URL:** <https://forum.inductiveautomation.com/t/best-way-to-return-data-from-vision-popup/92912>\
**Tags:** ignition81, vision\
**Created:** [July 8, 2024, 5:49pm UTC](https://forum.inductiveautomation.com/t/best-way-to-return-data-from-vision-popup/92912 "2024-07-08T17:49:41Z")\
**Showing post:** 20
**Post date:** [July 9, 2024, 6:36pm UTC](https://forum.inductiveautomation.com/t/best-way-to-return-data-from-vision-popup/92912/20 "2024-07-09T18:36:37Z")
Hmmm, this is one of the `PyComponentWrapper` gotchas, where jython won't recognize custom properties nor component custom methods.
If you can, install my Integration Toolkit to fix that for all cases. See more here, including a non-module solution:
> [@Why can't custom properties and methods be accessed from a component that is obtained using SwingUtilities.getAncestorOfClass?](https://forum.inductiveautomation.com/t/why-cant-custom-properties-and-methods-be-accessed-from-a-component-that-is-obtained-using-swingutilities-getancestorofclass/78606/2):
> Custom properties are added to the java standard jython conversion by IA's PyComponentWrapper. For a complete discussion, read this entire topic: TL/DR: Install my Simulation Aids Integration Toolkit module to magically fix this, everywhere in Ignition. There is no other solution until IA eventually does this first party. See below.
_[View the full topic](https://forum.inductiveautomation.com/t/best-way-to-return-data-from-vision-popup/92912)._
