# Bit-Level Addressing Function Code
**URL:** <https://forum.inductiveautomation.com/t/bit-level-addressing-function-code/72407>\
**Created:** [April 13, 2023, 2:06pm UTC](https://forum.inductiveautomation.com/t/bit-level-addressing-function-code/72407 "2023-04-13T14:06:25Z")\
**Showing post:** 3
**Post date:** [April 13, 2023, 2:43pm UTC](https://forum.inductiveautomation.com/t/bit-level-addressing-function-code/72407/3 "2023-04-13T14:43:52Z")
If it's because your device doesn't support Mask Write Register, you can use the workaround described [here](https://forum.inductiveautomation.com/t/troubles-making-a-derived-boolean-tag-work-as-a-mask-for-a-short-tag/15203/2).
It basically forces the masking to happen at a higher level, and then a whole register to be written, with the drawback that it's prone to a race condition where the register can change underneath you causing bits to be clobbered.
_[View the full topic](https://forum.inductiveautomation.com/t/bit-level-addressing-function-code/72407)._
