# \[Bug-13050\]After installing latest build, buttons, numeric entry fields etc are overriding styles with blue
**URL:** <https://forum.inductiveautomation.com/t/bug-13050-after-installing-latest-build-buttons-numeric-entry-fields-etc-are-overriding-styles-with-blue/23405>\
**Created:** [March 18, 2019, 4:49am UTC](https://forum.inductiveautomation.com/t/bug-13050-after-installing-latest-build-buttons-numeric-entry-fields-etc-are-overriding-styles-with-blue/23405 "2019-03-18T04:49:47Z")\
**Showing post:** 5
**Author:** ![ayu](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/ayu/32/16635_2.png) [@ayu](https://forum.inductiveautomation.com/u/ayu)\
**Post date:** [March 25, 2019, 11:59pm UTC](https://forum.inductiveautomation.com/t/bug-13050-after-installing-latest-build-buttons-numeric-entry-fields-etc-are-overriding-styles-with-blue/23405/5 "2019-03-25T23:59:18Z")
Hi ASF,
Can you show me an example of how you are trying to override the default styles?
If you haven't already, try following the steps outlined in this post:
> [@\[BUG-12227\] Button Background Color](http://forum.inductiveautomation.com/t/bug-12227-button-background-color/21647/8):
> If you ARE still seeing this issue, you will need to delete the CSS theme files located in Windows: C:\Program Files\Inductive Automation\Ignition\data\modules\com.inductiveautomation.perspective\themes macOS: /usr/local/ignition/data/modules/com.inductiveautomation.perspective/themes You would need to restart your gateway after deleting these files so that the new files can be placed properly.
_[View the full topic](https://forum.inductiveautomation.com/t/bug-13050-after-installing-latest-build-buttons-numeric-entry-fields-etc-are-overriding-styles-with-blue/23405)._
