# \[bug-14313\]Direct Tag Group running on Leased/Driven rate
**URL:** <https://forum.inductiveautomation.com/t/bug-14313-direct-tag-group-running-on-leased-driven-rate/27158>\
**Created:** [August 5, 2019, 12:51pm UTC](https://forum.inductiveautomation.com/t/bug-14313-direct-tag-group-running-on-leased-driven-rate/27158 "2019-08-05T12:51:15Z")\
**Author:** ![jlivingston](https://avatars.discourse-cdn.com/v4/letter/j/779978/32.png) [@jlivingston](https://forum.inductiveautomation.com/u/jlivingston)\
**Post date:** [August 5, 2019, 3:34pm UTC](https://forum.inductiveautomation.com/t/bug-14313-direct-tag-group-running-on-leased-driven-rate/27158/2 "2019-08-05T15:34:46Z")
Years ago there were other serial interface users looking for a repair to the system at Ignition 7.9, and there should be a colon here yet the forum text editor wants to make an emoji of it...
> [@System.serial UnsatisfiedLinkError (missing library?)](http://forum.inductiveautomation.com/t/system-serial-unsatisfiedlinkerror-missing-library/4913):
> Fresh install of Ignition 7.5.1, added the following modules: Serial Support Client 1.5.1 (b29) Serial Support Gateway 1.5.1 (b29) Created a button and added the following: system.serial.openSerialPort('/dev/ttyUSB0') Pressing the button results in the following: ERROR [ActionAdapter-AWT-EventQueue-0] \<HTML\>Error executing script for event:&nbsp;\<code\>\<b\>actionPerformed\</b\>\</code\>\<BR\>on component:&nbsp;\<code\>\<b\>Button\</b\>\</code\>. Traceback (most recent call last): File "\<event:actionPerfo…
So you might see if the users with known serial problems earlier have seen it under upgrade, or go to [https://support.inductiveautomation.com](https://support.inductiveautomation.com) and either check the knowledgebase, or (if you have not already done so) check the support policies before a voice call or e-mail.. Thanks for telling us what you have seen thus far. Inquiring minds ( and new students ) always wish to know.
_[View the full topic](https://forum.inductiveautomation.com/t/bug-14313-direct-tag-group-running-on-leased-driven-rate/27158)._
