# \[Bug-16627\]Ignition 8.0.13 - Perspective Style Classes not correctly applied to some input fields
**URL:** <https://forum.inductiveautomation.com/t/bug-16627-ignition-8-0-13-perspective-style-classes-not-correctly-applied-to-some-input-fields/35472>\
**Created:** [June 9, 2020, 8:57pm UTC](https://forum.inductiveautomation.com/t/bug-16627-ignition-8-0-13-perspective-style-classes-not-correctly-applied-to-some-input-fields/35472 "2020-06-09T20:57:33Z")\
**Showing post:** 8
**Author:** ![dkylep](https://avatars.discourse-cdn.com/v4/letter/d/6de8d8/32.png) [@dkylep](https://forum.inductiveautomation.com/u/dkylep)\
**Post date:** [June 10, 2020, 3:07pm UTC](https://forum.inductiveautomation.com/t/bug-16627-ignition-8-0-13-perspective-style-classes-not-correctly-applied-to-some-input-fields/35472/8 "2020-06-10T15:07:04Z")
This may be the same issue I ran into, here's how I'm currently solving it.
> [@\[NEW\] Theming Update: Major Visual Changes in Perspective](http://forum.inductiveautomation.com/t/new-theming-update-major-visual-changes-in-perspective/34020/27):
> I am a huge fan of the theme update, thank you very much! I did however find one aspect of the theme’s that I don’t really like. The background color on the selected items dropdown ‘valuePill’ [image] [image] Is there a straight forward way in the designer to change this color? I could not find an easy way to change this color. I was able to change the style in the CSS files by locating the relavant style .ia\_dropdown\_\_valuePill { border-radius: var(--borderRadius); background-co…
Looks like a recent 8.0.14 nightly may have a fix but I haven't tried it
> [@Nightly 8.0 Changelogs - 2020](http://forum.inductiveautomation.com/t/nightly-changelogs-2020/31153/91):
> Nightly Changelog: 8.0.14-b20200605 Ignition Platform 16373: Wildcard subscriptions don’t work with remote providers, MQTT transmission won’t work Fixed issue with wildcard subscription. 16467: Auto-Generation of Relative Paths in UDT Definitions is broken Fixed issue with UDT paths. 16279: Mulit-Instance Wizard uses incorrect UDT parameters for non default providers When creating UDT instances with the Multi-Instance wizard the params are now sourced from the correct provider. 16518: Spe…
_[View the full topic](https://forum.inductiveautomation.com/t/bug-16627-ignition-8-0-13-perspective-style-classes-not-correctly-applied-to-some-input-fields/35472)._
