[Bug] Core Historian merging history from different tags
Version 8.3.9
Ran into this issue today. I have two tags, comp_outlet_pressure/val and storage_pressure/val that have history enabled for a Core Historian instance with Data Deduplication not enabled. The tags are distinct OPC tags that reference separate sources, but one of them was created by copy-and-pasting the other and then modifying the parameters and name. (comp_outlet_pressure was first).
However, when I open the Tag Browser on the Power Chart, only one of the tags is shown:
If I manually add the missing tag "comp_outlet_pressure/val" as a new pen, it shows the same value as "storage_pressure/val". And the trend itself (both pens are identical) seems to have combined both tags! Note how there are sudden swings in the value, which corresponds to entries from each tag being recorded together into the same source.
Deleting/recreating tags did not work fix it, nor did restarting the tags or disabling and re-enabling history. I had to restart the Gateway to resolve the issue, which is fine because this is a test instance, but would be unacceptable in production. The fix was not retroactive either.
Any ideas?
