# \[BUG\]Multi-State Button/Toggle Button Control/Indicator Bindings Programmable Simulator Device
**URL:** <https://forum.inductiveautomation.com/t/bug-multi-state-button-toggle-button-control-indicator-bindings-programmable-simulator-device/59138>\
**Created:** [May 2, 2022, 9:55pm UTC](https://forum.inductiveautomation.com/t/bug-multi-state-button-toggle-button-control-indicator-bindings-programmable-simulator-device/59138 "2022-05-02T21:55:27Z")\
**Showing post:** 3
**Author:** ![amarks](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/amarks/32/45610_2.png) [@amarks](https://forum.inductiveautomation.com/u/amarks)\
**Post date:** [May 3, 2022, 11:18pm UTC](https://forum.inductiveautomation.com/t/bug-multi-state-button-toggle-button-control-indicator-bindings-programmable-simulator-device/59138/3 "2022-05-03T23:18:34Z")
Vision module on Ignition 8.1.16
This binding is on a template that is used on multiple other windows.
I have a Programmable Simulator Device that is supplying the OPC values. The values for these boolean tags are just set at static true/false.
The tags are combined under a UDT.
The tag quality is good and I am able to read/write each tag value from the tag browser.
My parameter to the template is a string that I use to create indirect bindings to the tags of interest within the UDT.
I have internal template properties bound (bidirectionally) to the UDT tags using indirection. For instance, `Hi_Alarm_En` (bool) and `Hi_Alarm_Delay` (int).
The internal template properties are then bound to individual component properties. For instance, `Hi_Alarm_En` is bound to the control value (bidirectionally) and indicator value of a 2-state toggle button.
This is repeated 3 times on the template for `Hi_Alarm_En`, `Lo_Alarm_En`, and `Signal_Alarm_En`, along with numeric input boxes for the delay inputs for each.
I did not have the issue with the low or signal tags, and the issue with the hi tags is intermittent. I just opened up designer (for the first time today) and no errors (no change to the project since posting).
_[View the full topic](https://forum.inductiveautomation.com/t/bug-multi-state-button-toggle-button-control-indicator-bindings-programmable-simulator-device/59138)._
