v8.1.41
It would appear that filtering is broken in the GUI Tag Report tool in this version. Whatever I type in, the result count remains the same. It seems that none of the parameters are being used... Copying to script yields the same default script with any number of parameters defined
@nminchin, The script count is limited to 100 based on the default query that we generate, is this potentially part of the issue?
I am not seeing the issue when attempting to duplicate the copying issue locally:
If the Designer is restarted, does the behavior change at all?
Are there any errors in the Designer console at all?
