# Bug? - UDT Instance import via csv not importing parameter values anymore
**URL:** <https://forum.inductiveautomation.com/t/bug-udt-instance-import-via-csv-not-importing-parameter-values-anymore/28399>\
**Tags:** ignition80\
**Created:** [September 19, 2019, 4:18pm UTC](https://forum.inductiveautomation.com/t/bug-udt-instance-import-via-csv-not-importing-parameter-values-anymore/28399 "2019-09-19T16:18:49Z")\
**Showing post:** 3
**Author:** ![Tim.Johnson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/tim.johnson/32/10597_2.png) [@Tim.Johnson](https://forum.inductiveautomation.com/u/Tim.Johnson)\
**Post date:** [September 20, 2019, 5:41pm UTC](https://forum.inductiveautomation.com/t/bug-udt-instance-import-via-csv-not-importing-parameter-values-anymore/28399/3 "2019-09-20T17:41:51Z")
Thanks @Paullys50.
I ended up writing a script to handle the process and posted an [example](http://forum.inductiveautomation.com/t/mass-import-of-udt-tags-via-simple-csv-and-script-example/28439?u=tim.johnson).
The reason I like csv files so much is because of their simplicity. Each tag consists of a single line with any parameter values listed in subsequent columns according to a header. I’ll admit, I’m not an xml guru, but am familiar with it, and still I find it (for this purpose anyway) a bit ‘bulky’.
_[View the full topic](https://forum.inductiveautomation.com/t/bug-udt-instance-import-via-csv-not-importing-parameter-values-anymore/28399)._
