# Camera Issue in Client
**URL:** <https://forum.inductiveautomation.com/t/camera-issue-in-client/15714>\
**Created:** [October 19, 2017, 12:56pm UTC](https://forum.inductiveautomation.com/t/camera-issue-in-client/15714 "2017-10-19T12:56:58Z")\
**Author:** ![0sm0](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/0sm0/32/15228_2.png) [@0sm0](https://forum.inductiveautomation.com/u/0sm0)\
**Post date:** [October 20, 2017, 2:05am UTC](https://forum.inductiveautomation.com/t/camera-issue-in-client/15714/2 "2017-10-20T02:05:23Z")
Is the Client on the same network as the Camera and Gateway?
If they are on different subnets you will have to use the gateway as a proxy for the camera.
Turn on the proxy in the Ignition Config file or check if already there…
Under Java Additional parameters add…
wrapper.java.additional.10=-Dvision.urlproxy.enabled=true
In the designer have the URL point to the proxy first…
http://[gateway IP]:8088/main/system/urlproxy?url=[camera url]
hope this helps
cheers
_[View the full topic](https://forum.inductiveautomation.com/t/camera-issue-in-client/15714)._
