# Can I modify an entire column from a dataset with system.dataset.setValue()?
**URL:** <https://forum.inductiveautomation.com/t/can-i-modify-an-entire-column-from-a-dataset-with-system-dataset-setvalue/87043>\
**Tags:** python, vision, scripting\
**Created:** [March 8, 2024, 3:39pm UTC](https://forum.inductiveautomation.com/t/can-i-modify-an-entire-column-from-a-dataset-with-system-dataset-setvalue/87043 "2024-03-08T15:39:29Z")\
**Showing post:** 3
**Post date:** [March 8, 2024, 4:23pm UTC](https://forum.inductiveautomation.com/t/can-i-modify-an-entire-column-from-a-dataset-with-system-dataset-setvalue/87043/3 "2024-03-08T16:23:52Z")
```python
def mapColumn(function, dataset, column):
	if isinstance(column, basestring):
		column = dataset.getColumnIndex(column)
	columnData = map(function, dataset.getColumnAsList(column))
	columnsToKeep = range(dataset.columnCount)
	columnsToKeep.pop(column)
	dsWithoutColumn = system.dataset.filterColumns(dataset, columnsToKeep)
	return system.dataset.addColumn(
		dsWithoutColumn,
		column,
		columnData,
		dataset.getColumnName(column),
		dataset.getColumnType(column)
It's relatively easy to create a 'mapColumn' function composed of our base primitives. This will be pretty efficient.
Usage is pretty simple - just declare a function that performs the calculation you want, for each value in the column, then supply it (no parenthesis!) to the mapColumn function:
```python
# usage:
def updateColumn(value):
	return value * 2
updatedDs = mapColumn(updateColumn, ds, "b")
On my test dataset, this does what you'd expect:
```auto
a | b | c
1 | 2 | 3
4 | 5 | 6
a | b | c
1 | 4 | 3
4 | 10 | 6
_[View the full topic](https://forum.inductiveautomation.com/t/can-i-modify-an-entire-column-from-a-dataset-with-system-dataset-setvalue/87043)._
