# Can Ignition read PointI/O?
**URL:** <https://forum.inductiveautomation.com/t/can-ignition-read-pointi-o/31047>\
**Created:** [January 3, 2020, 4:26pm UTC](https://forum.inductiveautomation.com/t/can-ignition-read-pointi-o/31047 "2020-01-03T16:26:10Z")\
**Author:** ![GreggCavazos](https://avatars.discourse-cdn.com/v4/letter/g/90db22/32.png) [@GreggCavazos](https://forum.inductiveautomation.com/u/GreggCavazos)\
**Post date:** [January 3, 2020, 4:50pm UTC](https://forum.inductiveautomation.com/t/can-ignition-read-pointi-o/31047/2 "2020-01-03T16:50:58Z")
Thats sounds like an application for the Ethernet/IP module from Automation Pros.
> [@Ethernet/IP I/O Module](http://forum.inductiveautomation.com/t/ethernet-ip-i-o-module/12362):
> Automation Professionals is pleased to announce the public beta for its latest module in the showcase: [Ethernet/IP Class 1 Communications](https://inductiveautomation.com/moduleshowcase/module/automation-professionals-llc-ethernetip-class-1-communications):[quote]Provides I/O Scanning and I/O Emulation on top of partial emulation of a Logix processor (Controller Tags and User-Defined data types). Use robust, low latency UDP packets to communicate with Logix processors as one or more I/O modules (passive slave mode), and with a variety of Ethernet/IP I/O modules as an I/O scanner (active master mode). With the Co…
@pturmel
_[View the full topic](https://forum.inductiveautomation.com/t/can-ignition-read-pointi-o/31047)._
