# Cannot read/write a plc5 float
**URL:** <https://forum.inductiveautomation.com/t/cannot-read-write-a-plc5-float/8829>\
**Created:** [July 31, 2014, 11:15am UTC](https://forum.inductiveautomation.com/t/cannot-read-write-a-plc5-float/8829 "2014-07-31T11:15:37Z")\
**Posts on this page:** 4\
**Author:** ![giles](https://avatars.discourse-cdn.com/v4/letter/g/c68b51/32.png) [@giles](https://forum.inductiveautomation.com/u/giles)\
**Post date:** [July 31, 2014, 11:15am UTC](https://forum.inductiveautomation.com/t/cannot-read-write-a-plc5-float/8829/1 "2014-07-31T11:15:37Z")
Hi I am using the allen bradley ethernet driver with a PLC5 - but it will not read/write a float eg F15:0
any ideas anybody?
**Post date:** [July 31, 2014, 12:53pm UTC](https://forum.inductiveautomation.com/t/cannot-read-write-a-plc5-float/8829/2 "2014-07-31T12:53:29Z")
Are there any errors in the console on the gateway when you attempt to read or write? The tag does show up in the browse though?
**Post date:** [July 31, 2014, 2:18pm UTC](https://forum.inductiveautomation.com/t/cannot-read-write-a-plc5-float/8829/3 "2014-07-31T14:18:47Z")
Hi
By which I assume you mean.
System
Status
Licensing
Backup/Restore
-\>Console
User Manual
If so there are two like this:
15:14:00 DefaultExceptionMapper Connection lost, give up responding.
org.apache.wicket.protocol.http.servlet.ResponseIOException: org.eclipse.jetty.io.EofException
at org.apache.wicket.protocol.http.servlet.ServletWebResponse.flush(ServletWebResponse.java:268)
at org.apache.wicket.protocol.http.HeaderBufferingWebResponse.flush(HeaderBufferingWebResponse.java:92)
at org.apache.wicket.request.resource.AbstractResource.flushResponseAfterHeaders(AbstractResource.java:633)
at org.apache.wicket.request.resource.AbstractResource.setResponseHeaders(AbstractResource.java:619)
at org.apache.wicket.request.resource.AbstractResource.respond(AbstractResource.java:493)
at org.apache.wicket.request.handler.resource.ResourceRequestHandler.respond(ResourceRequestHandler.java:75)
at org.apache.wicket.request.handler.resource.ResourceReferenceRequestHandler.respond(ResourceReferenceRequestHandler.java:108)
but I don’t think they are related.
I can’t browse any data in the plc - not sure I am meant to be able to with a plc5? However it works for integers just not floats
**Post date:** [July 31, 2014, 2:59pm UTC](https://forum.inductiveautomation.com/t/cannot-read-write-a-plc5-float/8829/4 "2014-07-31T14:59:00Z")
Ah ignore this I seem to have tags in my database whi8ch don;t actually exist in the plc Thanks for your help
