# Carousel doesn't render Labels with Fade: False
**URL:** <https://forum.inductiveautomation.com/t/carousel-doesnt-render-labels-with-fade-false/33718>\
**Created:** [April 6, 2020, 7:03pm UTC](https://forum.inductiveautomation.com/t/carousel-doesnt-render-labels-with-fade-false/33718 "2020-04-06T19:03:49Z")\
**Showing post:** 5
**Author:** ![jball](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/jball/32/11128_2.png) [@jball](https://forum.inductiveautomation.com/u/jball)\
**Post date:** [April 7, 2020, 8:52pm UTC](https://forum.inductiveautomation.com/t/carousel-doesnt-render-labels-with-fade-false/33718/5 "2020-04-07T20:52:56Z")
@kyle.demerath, there was a summary written about the work in Paul's Nightly Changelog post:
> [@Nightly 8.0 Changelogs - 2020](http://forum.inductiveautomation.com/t/nightly-changelogs-2020/31153/49):
> Nightly Changelog: 8.0.11-b20200327 Ignition Platform 15543: add system.user.addCompositeSchedule() Added system.user.addCompositeSchedule(), allowing two schedules to be combined into a composite schedule through scripting. Perspective 15853 Re-implement carousel to improve stability, performance and behavior Made several behavioral and performance related improvements to the perspective carousel component. In addition, support for drag transition while rotated was added, allowing users to…
The API is identical; this was just a rebuild of the internal logic and removing a library dependency. There were some layout issues with the previous carousel that may have forced you to add style to your views (slides) to get them to align correctly. If that's the case, you can remove anything like that. Each slide displays from its top, right corner inside of the carousel.
With regard to the slowness that you mentioned... Can you elaborate on what you are seeing there?
Also, I'd recommend reverting to the stable release of 8.0.10 vs the Release Candidate (RC). RCs may still include bugs and should really be used for testing features/fixes.
_[View the full topic](https://forum.inductiveautomation.com/t/carousel-doesnt-render-labels-with-fade-false/33718)._
