# Connecting PLCs with the same IP address
**URL:** <https://forum.inductiveautomation.com/t/connecting-plcs-with-the-same-ip-address/35082>\
**Created:** [May 27, 2020, 2:42pm UTC](https://forum.inductiveautomation.com/t/connecting-plcs-with-the-same-ip-address/35082 "2020-05-27T14:42:20Z")\
**Showing post:** 7
**Author:** ![wking](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/wking/32/21823_2.png) [@wking](https://forum.inductiveautomation.com/u/wking)\
**Post date:** [May 27, 2020, 5:09pm UTC](https://forum.inductiveautomation.com/t/connecting-plcs-with-the-same-ip-address/35082/7 "2020-05-27T17:09:41Z")
Couldn't recommend this bad-boy enough (500$):
> **[MikroTik](https://mikrotik.com/product/crs354_48g_4splus2qplusrm)**
> MikroTik makes networking hardware and software, which is used in nearly all countries of the world. Our mission is to make existing Internet technologies faster, more powerful and affordable to wider range of users.
Might be helpful:
> [@Can anyone recommend a 48 port rack-mountable NAT Switch/Router?](http://forum.inductiveautomation.com/t/can-anyone-recommend-a-48-port-rack-mountable-nat-switch-router/32683):
> I have 36 machines. They are all copies of each other as far as the network goes. PLC is always kept at 192.168.0.100. The idea is to run a line to every machine. And do 1:1 Port Aware NAT translation. Plugging into the spare port on PLC comm coprocessor. They’re L18s or whatever so no extra network card. Right? The server lives at: 120.120.80.212 For example: Port 1 --\> 192.168.0.100:44818 --\> 120.120.80.1 \<–\> Server Port 2 --\> 192.168.0.100:44818 --\> 120.120.80.2 \<–\> Server I have a coupl…
I plan on updating this post. With a guide of sorts.
With what I, as a very novice network/IT eng, did when I was in your situation.
But, basically you need to set up a network device to isolate ports from each other. And NAT 1:1 translate packets between devices and server.
Or you could use a device for every machine. Like with what was mentioned above. With Stratix switches or something. If $$$ isn't an issue. I'd go that way.
_[View the full topic](https://forum.inductiveautomation.com/t/connecting-plcs-with-the-same-ip-address/35082)._
