# Connection to 3rd party software with Ignition OPC UA Server
**URL:** <https://forum.inductiveautomation.com/t/connection-to-3rd-party-software-with-ignition-opc-ua-server/36818>\
**Created:** [July 17, 2020, 11:04am UTC](https://forum.inductiveautomation.com/t/connection-to-3rd-party-software-with-ignition-opc-ua-server/36818 "2020-07-17T11:04:41Z")\
**Showing post:** 7
**Post date:** [July 20, 2020, 12:18pm UTC](https://forum.inductiveautomation.com/t/connection-to-3rd-party-software-with-ignition-opc-ua-server/36818/7 "2020-07-20T12:18:55Z")
Yes.
If your client is running on a different machine you’ll also have to configure Ignition’s OPC UA server to bind to 0.0.0.0 instead of localhost. You can do this under Config \> OPC UA \> Server Settings and then change the Bind Address setting. You’ll have to restart for the change to take affect.
The endpoint URL will be `opc.tcp://<ip>:62541/discovery`.
_[View the full topic](https://forum.inductiveautomation.com/t/connection-to-3rd-party-software-with-ignition-opc-ua-server/36818)._
