# Create a taglist to import in ingition
**URL:** <https://forum.inductiveautomation.com/t/create-a-taglist-to-import-in-ingition/8961>\
**Category:** General Discussion\
**Created:** [August 27, 2014, 7:57am UTC](https://forum.inductiveautomation.com/t/create-a-taglist-to-import-in-ingition/8961 "2014-08-27T07:57:44Z")\
**Posts on this page:** 2\
**Author:** ![StefanGronberg](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/stefangronberg/32/6288_2.png) [@StefanGronberg](https://forum.inductiveautomation.com/u/StefanGronberg)\
**Post date:** [August 27, 2014, 7:57am UTC](https://forum.inductiveautomation.com/t/create-a-taglist-to-import-in-ingition/8961/1 "2014-08-27T07:57:44Z")
Hi, im currently writing a smaller application to parse a print out from Simatic (mainly datablocks)
to convert it into a xml-file to import in ignition.
However, i cannot seem to figure out the struct-parts and how/where the {offset} comes from or are set at by looking in [sqltags.xml](https://us1.discourse-cdn.com/inductiveautomation/original/2X/8/85a2eec5a40e313e172a9dd0f908f6d03000838a.xml) (79 KB)
The more normal tags, are much easier to understand and convert to from the simatic format.
**Post date:** [August 27, 2014, 10:01am UTC](https://forum.inductiveautomation.com/t/create-a-taglist-to-import-in-ingition/8961/2 "2014-08-27T10:01:32Z")
Hi Stefan,
There’s a similar thread? A lot of dry and non-useful stuff at the beginning, but if you start [around here](https://inductiveautomation.com/forum/viewtopic.php?p=45292#p45292), this gives some stuff that may actually help you out. I was working with Anton on a script that grabs an ASCII export and generates the XML file for alarms.
