# Created an OPC UDT but most elements show up as "Error\_Configuration" (Node ID does not exist)
**URL:** <https://forum.inductiveautomation.com/t/created-an-opc-udt-but-most-elements-show-up-as-error-configuration-node-id-does-not-exist/107795>\
**Tags:** vision, ignition81\
**Created:** [June 25, 2025, 7:11pm UTC](https://forum.inductiveautomation.com/t/created-an-opc-udt-but-most-elements-show-up-as-error-configuration-node-id-does-not-exist/107795 "2025-06-25T19:11:13Z")\
**Showing post:** 13
**Post date:** [June 26, 2025, 12:07am UTC](https://forum.inductiveautomation.com/t/created-an-opc-udt-but-most-elements-show-up-as-error-configuration-node-id-does-not-exist/107795/13 "2025-06-26T00:07:50Z")
> [@michael.flagler](#):
> but only makes it so that communications can be optimized to the tags in the PLC
But _only_ if you use Phil's [EtherNet IP driver module](https://forum.inductiveautomation.com/t/automation-professionals-ethernet-ip-communication-suite-v2/68190). IA's Logix driver will not optimise this regardless of AOI parameter external access settings, as these methods are not publicly documented. Phil spent the time reverse-engineering the protocol to allow this
_[View the full topic](https://forum.inductiveautomation.com/t/created-an-opc-udt-but-most-elements-show-up-as-error-configuration-node-id-does-not-exist/107795)._
