# Creating a .modl file of external Java Drivers code using Gradle in IntelliJ
**URL:** <https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210>\
**Created:** [July 15, 2024, 6:44am UTC](https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210 "2024-07-15T06:44:29Z")\
**Showing post:** 14
**Author:** ![kcollins](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/kcollins/32/19646_2.png) [@kcollins](https://forum.inductiveautomation.com/u/kcollins)\
**Post date:** [July 24, 2024, 7:20pm UTC](https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210/14 "2024-07-24T19:20:41Z")
I've logged [an issue](https://github.com/inductiveautomation/ignition-module-tools/issues/49) in our ignition-module-tools repo related to the error above.
While removing `moduleDependenciesSpec` will result in a successful build, the better workaround might be to replace the plugin configuration at the top of your root `build.gradle.kts` with version [`0.3.0`](https://github.com/inductiveautomation/ignition-module-tools/releases) (latest at time of writing).
 ![SCR-20240724-mtjp](https://us1.discourse-cdn.com/inductiveautomation/original/3X/8/e/8e51c275c2877e9c8d007f48490826b42f79e8fd.png)
_[View the full topic](https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210)._
