# Creating a .modl file of external Java Drivers code using Gradle in IntelliJ
**URL:** <https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210>\
**Created:** [July 15, 2024, 6:44am UTC](https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210 "2024-07-15T06:44:29Z")\
**Showing post:** 25
**Author:** ![Brian\_Ray](https://avatars.discourse-cdn.com/v4/letter/b/e0b2c6/32.png) [@Brian\_Ray](https://forum.inductiveautomation.com/u/Brian_Ray)\
**Post date:** [August 30, 2024, 3:52pm UTC](https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210/25 "2024-08-30T15:52:11Z")
The `moduleDependencySpecs` resolve exception should be [fixed now in `0.4.0`](https://forum.inductiveautomation.com/t/io-ia-sdk-modl-gradle-plugin-and-module-generator-releases/95376). I tested this locally after syncing up all the version references between the `generator` and `gradle-module-plugin` halves of the monorepo.
_[View the full topic](https://forum.inductiveautomation.com/t/creating-a-modl-file-of-external-java-drivers-code-using-gradle-in-intellij/93210)._
