# Creating and defining a dataset in Vision
**URL:** <https://forum.inductiveautomation.com/t/creating-and-defining-a-dataset-in-vision/92448>\
**Tags:** vision, ignition81\
**Created:** [June 27, 2024, 9:57am UTC](https://forum.inductiveautomation.com/t/creating-and-defining-a-dataset-in-vision/92448 "2024-06-27T09:57:55Z")\
**Showing post:** 7
**Author:** ![Omer\_Oren](https://avatars.discourse-cdn.com/v4/letter/o/5f8ce5/32.png) [@Omer\_Oren](https://forum.inductiveautomation.com/u/Omer_Oren)\
**Post date:** [July 1, 2024, 1:06pm UTC](https://forum.inductiveautomation.com/t/creating-and-defining-a-dataset-in-vision/92448/7 "2024-07-01T13:06:45Z")
Of course there must be modifications to suit my needs, I didn't mention it as it seemed trivial.
The editability shouldn't just remain in the table, the new values were supposed to actually update the tag.
I've actually got some of this to work by running the code in the table's propertyChange event based on [this](https://forum.inductiveautomation.com/t/create-dataset-and-assign-to-table-data/22948/7) thread. However, since I couldn't get tag data to appear in there I don't know if this would have created live values or a single data pull.
I tried to read tag values this based on [this thread](https://forum.inductiveautomation.com/t/wanting-to-add-data-to-dataset/27437/5) here, modified to a single tag for the test, but my project refuses to read the path and I can't understand what it is that I'm doing wrong.
The reason I'm trying to get a table to work is that I initially tried just placing numeric text fields side by side to get the "table look", but when I open the project on a different size screen it looks bad with out of alignment cells etc. and I'm not sure how a row of those fields set as a template (and stacked vertically via the template repeater) will look.
_[View the full topic](https://forum.inductiveautomation.com/t/creating-and-defining-a-dataset-in-vision/92448)._
