# Database connection pool size
**URL:** <https://forum.inductiveautomation.com/t/database-connection-pool-size/8929>\
**Created:** [August 20, 2014, 2:23pm UTC](https://forum.inductiveautomation.com/t/database-connection-pool-size/8929 "2014-08-20T14:23:39Z")\
**Posts on this page:** 2\
**Author:** ![Javachon](https://avatars.discourse-cdn.com/v4/letter/j/ac8455/32.png) [@Javachon](https://forum.inductiveautomation.com/u/Javachon)\
**Post date:** [August 20, 2014, 2:23pm UTC](https://forum.inductiveautomation.com/t/database-connection-pool-size/8929/1 "2014-08-20T14:23:39Z")
I would like to have some guidelines about database connection pool size in Ignition. We are about to buy a MS SQL Server licence and we wonder if we are better to go with a per connection or a per core licensing. We have many Ignition SQL Bridge Limited installations that push data to the same database server. Each Ignition SQL Bridge Limited is used only to run a couple (from 5 to 20) of historical transaction groups at low frequency (once per 5 minutes). So, what is the minimal number of connections that each Ignition SQL Bridge Limited should require? Can we limit the connection pool size to a single connection ?
Thanks!
Martin
**Author:** ![greg.simpson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/greg.simpson/32/3135_2.png) [@greg.simpson](https://forum.inductiveautomation.com/u/greg.simpson)\
**Post date:** [August 25, 2014, 7:00pm UTC](https://forum.inductiveautomation.com/t/database-connection-pool-size/8929/2 "2014-08-25T19:00:23Z")
The default number of poolable connection is set to 8. You can certainly lower this to 1 connection, but I would not advise this. If you have some slow/long running queries you will be backing up the communication with the database.
As for what license to purchase, I don’t think we can answer that for you. I would suggest contacting your Microsoft SQL Server sales rep and discussing your needs with them.
