# Demo install, connection rejected
**URL:** <https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573>\
**Created:** [June 16, 2014, 2:46pm UTC](https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573 "2014-06-16T14:46:37Z")\
**Posts on this page:** 5\
**Author:** ![rip](https://avatars.discourse-cdn.com/v4/letter/r/e99b99/32.png) [@rip](https://forum.inductiveautomation.com/u/rip)\
**Post date:** [June 16, 2014, 2:46pm UTC](https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573/1 "2014-06-16T14:46:37Z")
Hiya,
MacOS 10.9.3 core i5 16Gig 2.6GHz [below for System Properties out of Ignition Gateway]
Demo, time remaining on this launch is ~20min
About every 10 sec, I get:
10:33:40 AM | OpcUaConnection:Ignition OPC-UA Server | Error connecting to server: StatusCode[Severity=Bad, Subcode=Bad\_ConnectionRejected]
There are three demo PLCs (one each of Dairy, Generic, SLC). All three show “Connected” and enabled “true”.
I am trying to access the tags in Designer, and getting an empty tree after clicking the refresh arrow, approximating:
– \* Ignition OPC-UA Server
The output console has nothing after “Starting tag polling” (i’d copy/paste the actual line, but copy fills the buffer with a bunch of xml and not the actual line… ![:scratch:](https://us1.discourse-cdn.com/inductiveautomation/original/1X/76d1620bec252bfac07050c889ff5a91dc8a9c25.gif ":scratch:")
Suggestions? Is this a MacOS firewall thing?
regards,
rip
System Properties
Context State Running
Redundancy Mode Independent
Redundancy State Active
Version 7.6.6 (b2014040112)
Java Version Apple Inc. 1.6.0\_65
CPU % 9.5
Memory (used/max) 370 mb / 1,016 mb
Uptime 38 minutes, 56 seconds
Timezone America/New\_York [GMT-5:00]
Locale en\_US
Java Library Path lib:lib/core/gateway
**Post date:** [June 16, 2014, 4:36pm UTC](https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573/2 "2014-06-16T16:36:34Z")
On the gateway under Configure \> OPC-UA \> Settings make sure the ‘Endpoint Address’ setting matches the IP of your machine. If you end up having to change it you’ll need to restart the UA module or the gateway to for it to take effect.
Then under OPC Connections \> Servers make sure you have a connection that is going to either ‘localhost’ or to the IP from above.
**Post date:** [June 16, 2014, 5:47pm UTC](https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573/3 "2014-06-16T17:47:23Z")
That’s done it.
Is that step in the quick-start?
I think I was thrown by the status saying ok, but the log saying no, and then the Designer tool behavior agreeing with the no.
Thank you for your help!
Regards,
rip
**Post date:** [June 16, 2014, 5:53pm UTC](https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573/4 "2014-06-16T17:53:18Z")
I’m not sure if it’s in the quickstart or not - it’s not always necessary.
But if you’re on a laptop and your IP is changing you may find your OPC-UA connection is faulted, in which case this is usually a good first step in troubleshooting.
**Post date:** [June 16, 2014, 5:59pm UTC](https://forum.inductiveautomation.com/t/demo-install-connection-rejected/8573/5 "2014-06-16T17:59:44Z")
Excellent, and yeah – it’s a laptop.
I set it to “localhost” and that seems to be a suitable substitution. I think it was the VPN – the address in the field was the VPN supplied ip address, and that connection was probably firewalling stuff on the primary port.
I’m good.
Thanks for the quick response – most excellent time-to-resolution there.
rip
