# Drawing Tool Issues
**URL:** <https://forum.inductiveautomation.com/t/drawing-tool-issues/4659>\
**Created:** [June 19, 2012, 2:52am UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659 "2012-06-19T02:52:15Z")\
**Posts on this page:** 10\
**Author:** ![Joseph\_Mendonca](https://avatars.discourse-cdn.com/v4/letter/j/58f4c7/32.png) [@Joseph\_Mendonca](https://forum.inductiveautomation.com/u/Joseph_Mendonca)\
**Post date:** [June 19, 2012, 2:52am UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/1 "2012-06-19T02:52:15Z")
lines, polygons, squares all disappear when rotated in a container. X Y Coordinates after rotating is off the screen.
**Author:** ![greg.simpson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/greg.simpson/32/3135_2.png) [@greg.simpson](https://forum.inductiveautomation.com/u/greg.simpson)\
**Post date:** [June 19, 2012, 2:45pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/2 "2012-06-19T14:45:53Z")
Is this similar to what your issue is?
[viewtopic.php?f=72&t=7090](http://www.inductiveautomation.com/forum/viewtopic.php?f=72&t=7090)
Are the objects actually disappearing or are they just moving their X Y coordinates?
**Post date:** [June 19, 2012, 3:15pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/3 "2012-06-19T15:15:44Z")
Moving their x y coordinates. Objects disappear off the container. Thought this was fixed in an earlier version but it seems to reappear. refer to post “editing lines”
**Post date:** [June 19, 2012, 3:17pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/4 "2012-06-19T15:17:51Z")
What version of Ignition are you currently using?
**Post date:** [June 19, 2012, 3:56pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/5 "2012-06-19T15:56:22Z")
7.5.0 (b1079)
**Post date:** [June 19, 2012, 4:31pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/6 "2012-06-19T16:31:23Z")
I tried to recreate this on my computer here without success. I tried with various different shapes. I was able to rotate them without any problems and they never changed their X Y coordinates.
When you start to rotate the object, is the red cross that is centered on the object still centered on that object?
**Post date:** [June 19, 2012, 4:43pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/7 "2012-06-19T16:43:21Z")
I stand corrected, we were able to reproduce this. I will talk with the developers about this.
**Author:** ![Carl.Gould](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/carl.gould/32/7262_2.png) [@Carl.Gould](https://forum.inductiveautomation.com/u/Carl.Gould)\
**Post date:** [June 19, 2012, 10:53pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/8 "2012-06-19T22:53:23Z")
Were you rotating them using the “rotate 90 degrees left/right” buttons? If so, then the issue has been fixed for 7.5.1
**Post date:** [June 20, 2012, 4:05am UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/9 "2012-06-20T04:05:12Z")
correct the icons on top that look like L’s “rotate selection 90 degrees…”
**Post date:** [June 20, 2012, 5:46pm UTC](https://forum.inductiveautomation.com/t/drawing-tool-issues/4659/10 "2012-06-20T17:46:29Z")
Ok just making sure - issue is fixed.
