# Dumb question, is there a way to access memory address from pointers natively?
**URL:** <https://forum.inductiveautomation.com/t/dumb-question-is-there-a-way-to-access-memory-address-from-pointers-natively/117949>\
**Tags:** ignition81, perspective, scripting\
**Created:** [November 24, 2026, 3:10pm UTC](https://forum.inductiveautomation.com/t/dumb-question-is-there-a-way-to-access-memory-address-from-pointers-natively/117949 "2026-11-24T15:10:35Z")\
**Showing post:** 3
**Post date:** [November 24, 2026, 4:48pm UTC](https://forum.inductiveautomation.com/t/dumb-question-is-there-a-way-to-access-memory-address-from-pointers-natively/117949/3 "2026-11-24T16:48:39Z")
Since [we haven't yet done this first party](https://forum.inductiveautomation.com/t/ign-5244-using-class-instance-as-view-custom-object-property/53676), Phil implemented essentially what you're asking for in his integration toolkit module:
> [@Automation Professionals' Integration Toolkit Module](https://forum.inductiveautomation.com/t/automation-professionals-integration-toolkit-module/74934):
> Automation Professionals is pleased to announce the immediately availability of a major upgrade to its free Simulation Aids Integration Toolkit module. The new feature justifying the "major upgrade" language is the implementation of eleven thirty-one new expression functions which use iteration to accomplish complex transforms of datasets and lists, to or from other datasets and lists, applying filtering, ordering, and computed new columns along the way. While there are certain operations that…
> **[Perspective-Related Functions - Expression-Scripting Connectors - Integration...](https://www.automation-pros.com/toolkit/doc/scripting.html#perspective-related-functions)**
> Expression bindings and jython scripting have only one connector in the general case, Ignition’s native runScript() expression function. In Perspective, scripting transforms can also be tied to expressions. Integration Toolkit adds several additional...
_[View the full topic](https://forum.inductiveautomation.com/t/dumb-question-is-there-a-way-to-access-memory-address-from-pointers-natively/117949)._
