# Dynamic Check Box Selection in Table
**URL:** <https://forum.inductiveautomation.com/t/dynamic-check-box-selection-in-table/77692>\
**Tags:** perspective\
**Created:** [August 10, 2023, 12:22pm UTC](https://forum.inductiveautomation.com/t/dynamic-check-box-selection-in-table/77692 "2023-08-10T12:22:33Z")\
**Showing post:** 7
**Post date:** [September 10, 2023, 4:26am UTC](https://forum.inductiveautomation.com/t/dynamic-check-box-selection-in-table/77692/7 "2023-09-10T04:26:16Z")
Here is a way to do it.
**Step 1:** Follow the tutorial posted by Transistor to create a checkbox in a view that is rendered in your Boolean column
**Step 2:** Add a hidden column called enabled to your table's data property
**Step 3:** In your checkbox's view, add the rowData parameter
 ![image](https://us1.discourse-cdn.com/inductiveautomation/original/3X/0/0/00b5cedfde29e078ce8fc4a734d3b8d29714c42c.png)
**Step 4:** Bind your checkbox's enabled parameter to the view's rowData property, and add `.enabled` to the end of it.
 ![image](https://us1.discourse-cdn.com/inductiveautomation/original/3X/9/b/9ba19fd1d2495d495a0fc0b8b1aba38a65cd8406.png)
**Note:** This will result in a null value and a red dot on your checkbox, but ignore this because this isn't a problem.
 ![image](https://us1.discourse-cdn.com/inductiveautomation/original/3X/c/b/cb1a2f352f3abe6ae07079d93140492d339d31ae.png)
Once this is done, you can individually control the enabled property of each checkbox in your table by controlling the corresponding enabled value of the hidden column:
 ![image](https://us1.discourse-cdn.com/inductiveautomation/original/3X/3/a/3a09c54fcbccff718b803fec3144bb216895c98f.png)
_[View the full topic](https://forum.inductiveautomation.com/t/dynamic-check-box-selection-in-table/77692)._
