# Dynamic tag addition
**URL:** <https://forum.inductiveautomation.com/t/dynamic-tag-addition/8832>\
**Created:** [July 31, 2014, 4:31pm UTC](https://forum.inductiveautomation.com/t/dynamic-tag-addition/8832 "2014-07-31T16:31:12Z")\
**Posts on this page:** 4\
**Author:** ![Francisco.Mejia](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/francisco.mejia/32/63246_2.png) [@Francisco.Mejia](https://forum.inductiveautomation.com/u/Francisco.Mejia)\
**Post date:** [July 31, 2014, 4:31pm UTC](https://forum.inductiveautomation.com/t/dynamic-tag-addition/8832/1 "2014-07-31T16:31:12Z")
Is it possible to dynamically add tags (while the application is running) to a easy chart component ?
Francisco
**Author:** ![diat150](https://avatars.discourse-cdn.com/v4/letter/d/a587f6/32.png) [@diat150](https://forum.inductiveautomation.com/u/diat150)\
**Post date:** [July 31, 2014, 5:14pm UTC](https://forum.inductiveautomation.com/t/dynamic-tag-addition/8832/2 "2014-07-31T17:14:51Z")
yes, take a look at the tagpens dataset on the easy chart. this dataset. You would just need to add a row in that dataset for each tag that you want to add.
**Author:** ![Stevenson.Yuan](https://avatars.discourse-cdn.com/v4/letter/s/ac91a4/32.png) [@Stevenson.Yuan](https://forum.inductiveautomation.com/u/Stevenson.Yuan)\
**Post date:** [July 31, 2014, 11:38pm UTC](https://forum.inductiveautomation.com/t/dynamic-tag-addition/8832/3 "2014-07-31T23:38:09Z")
what diat said is correct, a script to add a row would work.
If you’re in 7.7+ you can utilize the tag browse tree which allows you to add pens based on your sql tags.
**Post date:** [August 1, 2014, 3:26pm UTC](https://forum.inductiveautomation.com/t/dynamic-tag-addition/8832/4 "2014-08-01T15:26:15Z")
Thanks!
