# Dynamically generated table use toggles instead of True/False?
**URL:** <https://forum.inductiveautomation.com/t/dynamically-generated-table-use-toggles-instead-of-true-false/76157>\
**Tags:** scripting, ignition81, perspective\
**Created:** [July 10, 2023, 7:40pm UTC](https://forum.inductiveautomation.com/t/dynamically-generated-table-use-toggles-instead-of-true-false/76157 "2023-07-10T19:40:08Z")\
**Showing post:** 5
**Author:** ![jlandwerlen](https://avatars.discourse-cdn.com/v4/letter/j/bc8723/32.png) [@jlandwerlen](https://forum.inductiveautomation.com/u/jlandwerlen)\
**Post date:** [July 10, 2023, 8:24pm UTC](https://forum.inductiveautomation.com/t/dynamically-generated-table-use-toggles-instead-of-true-false/76157/5 "2023-07-10T20:24:35Z")
> [@Editing Perspective table with allowEditOn single-click still takes two clicks](https://forum.inductiveautomation.com/t/editing-perspective-table-with-allowediton-single-click-still-takes-two-clicks/30446):
> I have a table with two columns that are editable, a boolean and a string. I set the onCellEdit field to “single-click” however the real functionality seems to be click once to select the row, then click again to check the boolean or start writing to the text column. Is there a way to make it truly be like a work on a single click? I tried to use the onFocus and onRowclick but nether tell me what column was clicked, which would be enough for me to then programatically just select the box. An…
_[View the full topic](https://forum.inductiveautomation.com/t/dynamically-generated-table-use-toggles-instead-of-true-false/76157)._
