# Easy char X trace Decimal limit
**URL:** <https://forum.inductiveautomation.com/t/easy-char-x-trace-decimal-limit/75131>\
**Tags:** vision\
**Created:** [June 16, 2023, 9:51am UTC](https://forum.inductiveautomation.com/t/easy-char-x-trace-decimal-limit/75131 "2023-06-16T09:51:09Z")\
**Showing post:** 10
**Post date:** [June 16, 2023, 1:57pm UTC](https://forum.inductiveautomation.com/t/easy-char-x-trace-decimal-limit/75131/10 "2023-06-16T13:57:24Z")
> [@prasath.t](#):
> tried like this system.date.format(yValue, "yyyy-MM-dd HH:mm:ss")
I have a solution to this question here:
> [@Easy Chart Xtrace & Mark Mode datetime format](https://forum.inductiveautomation.com/t/easy-chart-xtrace-mark-mode-datetime-format/67159/4):
> Update: I developed a work around that produces the desired effect by overriding the AutoTickDisplayDateAxis extension of the DateAxis and subsequently customizing the plot's date and time formats. Here is the code: def configureChart(self, chart): from java.text import SimpleDateFormat from org.jfree.chart.axis import DateAxis pureDateFormat = SimpleDateFormat("yyyy/MM/dd") pureTimeFormat = SimpleDateFormat("h:mm:ss a z") dateAxis = DateAxis() plot = chart.getPlot() plot.setDomainA…
_[View the full topic](https://forum.inductiveautomation.com/t/easy-char-x-trace-decimal-limit/75131)._
